Can a select one function only show values that meet a previous question's answer?
1171
03-18-2022 01:07 PM
GISManager4
I want users to select the Asset Type (Main, valve, hydrant, meter) and then only show those repair codes that relate to the asset type. Is this possible with Survey123?
Katie_Clark
MVP Regular Contributor
Yup! Sounds like you'll want to look into choice filters
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-choice-filters/ba-...
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
