Calculating Geopoint Does not Zoom
1100
06-05-2020 09:04 AM
KeithGerhartz1
I am using a select_single to obtain geopoint coords. However, the map is not zooming when the calculate is executed. I am doing exactly what is in the sample but no zoom. I am using linked content.
The point does appear on the map and changes based on what is selected. The map just stays at the full extent.
Any help would be appreciated. Thank you.
Shwu-jingJeng
Hi Keith,
Could you provide more details for us to look into this issue? What version of survey123 are you using? Did the issue only occur in Connect or field app, or both? Could you provide us your XLSForm for us to see how the calculation is set?
