Automatic Updating Inbox
1387
09-09-2020 05:40 AM
JulienCHARBONNAUD
we are working together on the same project and on the same surveys. To be sure that new entries are made on the last version entered, is there a solution to update the inbox each time an investigation is opened?
Thinks a lot
Julien
ZacharySutherby
Hello Julien CHARBONNAUD‌,
We have an Enhancement logged requesting this functionality. The Enhancement is "ENH-000125178: Please provide the ability to enable an "Auto-refresh" for the Survey123 for ArcGIS Inbox".
I would suggest logging a case with Esri Technical Support and they will be able to attach you to the Enhancement and you will be notified when the Enhancement reaches it's final solution.
Thank you,
Zach
Thank you,
Zach
JulienCHARBONNAUD
Thank you
I told myself that I had seen the information pass
Julien
