Autocomplete field with search() function using Android
895
10-26-2021 09:03 AM
gjhsduifhsdzukfhzkdsjfh
When using the search() functionality in conjunction with an autocomplete field it does not work with android devices. However, it works fine with IOS. Is this something that can be fixed? We have consultants using IOS and Android.
ZacharySutherby
Hello @gjhsduifhsdzukfhzkdsjfh
Are you using search() against a CSV or a feature service? When you say it is not working are no choices being populated, or are the choices not being filtered correctly?
Thank you,
Zach
I am using search() against a feature service and it will not allow me to interact with the field in any way, shape, or form when using the android device. I cannot type in the field or use the dropdown. . . .Everything works perfectly fine when using an OIS device.
