Are field parameters supported for custom URLs opening inbox and adding a repeat?
1150
08-11-2023 01:05 AM
ChristopherCounsell
MVP Frequent Contributor
Workflow is:
  1. Click on a point in Map Viewer to launch survey form from popup. Get record from globalid, open inbox, set to update. All works fine.
  2. Users are to submit a repeat. There are some calculations to capture the visit and update the point.
We want to pass a value from the pop-up into the repeat. The URL is fine but it doesn't seem to work.
Are field parameters supported when opening a survey in the inbox via a custom url?
Alternatively, does anyone have a suggestion on how to avoid a logic loop. We want to pass a number from the parent table into the repeat, to record the number, but also clear it from the parent table. The field parameter would help us do this without relying on the survey calculations.
Cheers! 🙂
ChristopherCounsell
@ZacharySutherby @DougBrowning might be a question for you experts - is passing a field value into an inbox survey supported?
I'm assuming not but not sure if I should invest time in trying to get it to work, or create an idea/enh request.
Cheers 🙂
