ArcGIS Solutions linked data with previous solution
998
03-10-2020 11:27 AM
EricBitner
I am reusing an ArcGIS Solution that I used last year.  Last years solution has data in Survey123 from the previous 2019 survey season.  I re deployed the same solution in order to set up a survey with the solution for the 2020 survey season.  When I went to configure the solution all the data from 2019 was automatically in the new solution.  When I began to delete the data is deleted it in both Surveys in Survey123.  Any help on how to unlink these surveys that were created from the Solutions page?
JamesTedrick
Esri Esteemed Contributor
Hi Eric,
Apologies for the delay.  You may want the ArcGIS Solutions‌ team to weigh in on this, but it sounds like you re-deployed a solution using the same names, which repointed everything to the already existing 2019 results, correct?  In that case, it sounds like you should re-publish to different names to distinguish the 2020 collection from the 2019 collection.
