Original User: ThomM
Hi Martin,
A very clear post. However I'm not exactly sure why it's not working; it sounds like it should be. Here are a few random suggestions which probably won't work 😉
One thing to check; are you stopping your edit session and saving your edits before performing your spatial join? If not, the geometry won't exist, so nothing can be joined to it. However, it sounds like you are getting results, so this probably isn't the problem.
What happens if you use the Intersect tool to intersect the polygon feature class with the points? Do you get a result then?
What is the number that you get each time? Is it related to anything sensible - the total number of features, or the total number of features for that player, or...? That might give you a hint about where to look.
Does the same thing happen if, rather than creating a layer from the selection, you actually export the selection as a new dataset? (After using Select by Attributes, right-click on the layer -> Data -> Export Data, make sure "Export selected features" is checked)
Are your polygon areas just a rectangular grid? If so, you can create them automatically with the Fishnet tool. This would be more reliable than your hand-drawn squares. You could also try using Point Statistics in Spatial Analyst, which would give you a raster output, which might not be what you want. If you have arbitrary polygons then this won't help 😛
I'd suggest reposting your question in the General ArcMap forum, that gets more traffic than this one here.
Let us know how you go!
Edit: Also, try running the "Repair geometry" tool on both of your feature classes. It's a bit of a black magic approach, and probably won't do anything, but it seems to fix a lot of these mysterious issues.
