Spillman Toolbar
4362
11-01-2012 01:56 PM
ChadFoster
I use a Spillman toolbar to produce outfiles for the Dispatch Center.  I recently upgraded my old computer from ARCGIS 9.3.1 to ARCGIS 10.0 and updated my toolbar as well.  There are a couple of tools on the toolbar that are not working:
1. Auto populate fields from zones - after running this tool, there are 600 or so lines that do not show the city code in the field for Rcitycd.
2. Create Zones  -  This tool is supposed to create a mastervalues.dbf and a tbzones.dbf, which it does, but both of these tables are empty except for the column names.
I am wondering if anyone else in the ESRI community produces outfiles for Spillman using the ARCGIS 10.0 add in toolbar?  If so, have you experienced any of the above problems?  If so, what do you suggest I do?
At this point, I am thinking of backloading 9.3.1 to produce the out files.
Thanks in advance for any help/advice.
Tags (1)
JoeBorgione
Call Spillman Tech Support; my guess is you have a wrong or bad build for the toolbar.  I just ran outfiles the other day, but I don't use the functions you mention: My streets have city codes and I keep a mastervalues and tbzones tables on hand...
That should just about do it....
