Is there any way of removing the storymap heading section? Once a storymap has been embedded into a collection it seems like overkill to have the heading within the menu bar at the top (where it's really helpful); and again in very big letters below!
Yep! That's the story cover. Just hover over the story in the collection builder overview page, click the gear, and then check the box to hide the cover.
There's no option to "Hide story cover" - Only options for Title and Thumbnail appears. Was this functionality removed?
@RichfieldMN -- No, this functionality wasn't removed. Is the item you are modifying a StoryMap? If so, did you add it from the ArcGIS Content option or the Embed option? The hide story cover option will only be available if you add the story via the ArcGIS Content option.
It was from Embed option. Thank you for clarifying it. I also have tried adding header=flase&cover=false to the url parameter, and it also didn't work. https://storymaps.arcgis.com/collections/2b11e1577294491fafca8645945a586d?header=flase&cover=false
Is there a way we can remove header from StoryMapCollections? (Where different tabs show different embeded content similar to what we can currently do with the old map series story map?
Thanks!
@RichfieldMN -- When adding a story via the Embed option you can add "?cover=false" to the URL to hide the cover. The header is already hidden when a story appears in a collection regardless of which way you add it.
There isn't currently a way to hide the header or cover for a collection since those elements are critical to navigation of the collection. If you want to start the collection showing the first item you can add add "?item=1" to the URL.
I didn't notice any change with "?cover=false"
As for "item=1" that's exactly what I am trying to accomplish. I would just need everything above the tabs to disappear. Is it possible? Thank you so much!
How can we do this in 2025?
@Laura This article describes a feature that may help you accomplish what you are looking to do:
StoryMap Collection "modes" - Esri Community
@RichfieldMN , the link above also may interest you.
Fantastic - thanks @OwenGeo !
