Remove Header from Story Map Builder
4615
03-17-2021 12:07 PM
SohrabMikanik
I would like to know if it is possible to have the header completely removed from the story map builder? The minimalistic header is still too large.
Any advice would help.
Thank you.
OwenGeo
Esri Notable Contributor
Hi @SohrabMikanik! The header and/or cover can be hidden for stories using URL parameters. Just add these parameters to the story URL.
  • Hide header: ?header=false
  • Hide cover: ?cover=false
  • Hide both: ?header=false&cover=false
For example:
https://storymaps.arcgis.com/stories/c87bc0a59c0144008e25d50a5dd1b192?header=false&cover=false
The header is automatically hidden when a story is embedded in another web page. If you want to force the header to show when embedded you can use ?header=true.
Owen Evans
OwenGeo
For example:
Owen Evans
KellyBoyd
Hello,
Is this supported in ArcGIS Enterprise 10.8.1?
Thanks so much,
Kelly
OwenGeo
@KellyBoyd -- This feature is not available in 10.8.1, but it will be in Enterprise 10.9.
Owen Evans
KellyBoyd
Thanks so much, @OwenGeo
