Problem embedding Survey123
1323
08-16-2019 02:39 AM
SebastianHavdelin
I'm trying to embed a survey created in Survery123. I don't get any embed-options in editing mode as with other embedded pages, just a spinning circle. The survey is visible though when I publish.
I would like to change the appearence of the embedded survey but the menu (and the survey) does not appear in editing mode.
OwenGeo
Esri Notable Contributor
Sebastian -- Sorry, there's a known issue with embedding Survey123 forms right now. We'll be fixing this in the next release at the end of this month.
For now, if you modify the survey link to be in the form shown below, it should work.
https://survey123.arcgis.com/share/?id=ebdbf854342e4dddad50adf66dd9f06d
(Instead of: https://survey123.arcgis.com/share/ebdbf854342e4dddad50adf66dd9f06d)
Owen Evans
AravindatStoryMaps
Hi Sebastian Havdelin
This issue should be resolved with our August update (Released on august 28th). Can you confirm if this is still a problem?
Aravind
