Zonal Statistics values are different then Statistics in info for my raster
1394
03-11-2025 07:47 AM
DéboraFanzeres
I have a raster that when I open it says it goes from 441 to 474, their values. I want to know the sum of the values in that raster, and when I use both zonal statistics or raster layer statistics to see the sum, the min and maximum it gives me is 166 till 621, so I am not sure what happens there and if I can even trust that sum they give me. Anyone can help? Thanks!
DanPatterson
MVP Esteemed Contributor
how is your zone or zones defined? and doe the raster extent and zonal extents match?
How zonal statistics tools work—ArcGIS Pro | Documentation
... sort of retired...
David_Brooks
MVP Regular Contributor
@DéboraFanzeres and have you built raster statistics on the raster dataset itself? it might be that the 441-474 values are an estimate
David
..Maps with no limits..
DavidPike
MVP Notable Contributor
The layer statistics are calculated from a sample with a skip factor.  It's possibly these values have been skipped.  I would use the calculate statistics tool with a value of 1.  That will update the dataset properties and then you can properly compare.
