Zonal Statistics - too many values?
5598
09-13-2011 07:29 AM
JamesHook
I have a large polygon layer representing a few thousand fields, and raster layer with 3 land cover classes.  I would like to summarize each field with a single land cover class, and the only tool I can think of to accomplish this is Zonal Statistics.
Problem is, when I try to run Zonal Statistics, I get ERROR 999999, "Too many unique values".  What are the limitations on this tool, and is there a better way to perform this summary?
JeffreySwain
You may be running into the limit of unique values in a raster.  Go to the Customize > ArcMap Options  > Raster Dataset.  Adjust the 'Maximum number of unique values to render.'  The default setting is to limit the processing time, so any adjustment up will increase the processing time.
JamesHook
Thanks!
For others who may be interested in a solution, it also worked to reduce the number of zones in the zone feature class.  Apparently this is a combination of value raster and zone layer size.
