Zonal Statistic As Table--Problem calculating MEAN-Values
10178
10
03-05-2012 09:35 PM
by Anonymous User
Not applicable
Original User: patflo
Hello i`ve got a problem doing the zonal statistic calculation with a layer and a shape-file. My layer is a temperature layer for europe and my shapefile is a polygon shapefile from Germany. When i want to do the MEAN calculation for every polygon in the shapefile it gives me MEAN-Values for the temperature of -1100 degrees. I think the problem is that some of the polygons are not fully covered by the raster layer? Has someone an idea how to get the correct values?
in the attachement i put a pic of the shapefile with the raster layer and the table.
Thanks in advance for your help
FlorianPattis
UPDATE: I tried to do the same task in the ArcGis 9.3 Version and it worked correct. There are no values with -1170 in the zonal statistics table so i think this is a bug in the Arcgis10 Version.
