Why the count does not match in Histogram and Attribute table ?
4729
11
09-22-2011 10:30 AM
MOHAMMEDHABBOUB
Hello everybody
I worked on Spatial analyst .. " Histogram"
But I have a question Why the count does not match in Histogram and Attribute table ?
see attached image
Weird, isn't it?
PLZ help
DanPatterson_Retired
grid tables give cell count which multiplied by the square of the cell width gives area...histogram, IMS...yields area...check in any event
MOHAMMEDHABBOUB
Well, It doesn't make sense.
The cell width is 25 so the area is 25*25=625
the Count in attribute table is 671722 but in Histogram is 466834
466834 + 625 =467459 not 671722
So Why?
What is even stranger is the class/value shown with identify (4) doesn't match that within the raster table (6).  In any event, you would multiply the cell area by the count to get area (which wouldn't help in your case anyway)
EricRice
Esri Alum
Greetings,
Try rebuilding the raster attribute table.  Some operations (tools) do not automatically update the count field.  For example, if you clip a raster, the result will have count values that reflect the original counts.  Maybe your table is out of sync with the data.  Just a thought.
Regards,
Eric
EricRice
Esri Alum
I just realized that is the landuse raster from the Spatial Analyst tutorial data.  I'm guessing you didn't do anything to it yet that would require a rebuild of the table?
MOHAMMEDHABBOUB
That's right Eric, this is from Spatial Analysis Tutorial and I did nothing to the raster yet... so there is no point in rebuilding.
So? is it a bug? or what?
did you try rebuilding to see if the original file is in error?
EricRice
Esri Alum
Your screenshot indicates you are using an old version of the software.  I can't reproduce this issue.  Can you upgrade?  It looks like a bug in an older product.
Regards,
Eric
MOHAMMEDHABBOUB
I will try to upgrade
