Unable to assign Pour Points Shapefile
8514
17
04-09-2015 07:24 AM
SamanArmal1
Hello everyone,
I need to delineate the Chesapeake Bay watershed. For this reason, I took 16 tiles of DEM production(Arcgrid) from USGS database and merge them through Mosaic Database. I ran spatial analyst toolbox (Fill, Flow Direction, Flow Accumulation respectively) with the same spatial references as that of dem datasets (GCS_North_American_1983). Now, when I want to define pour point Shapefile to finalize watershed delineation, It can not snap the cell with the high accumulation. I am sure that Geographic Coordination System is same for my all layers. But when I want to assign relevant cells into the Shapefile of pour-points, it show a warning in which alert for inconsistency between Shapefile and one of the layers (Attachment-1). Also the result of flow accumulation doesn't seem to be satisfactory (Please see Attachment-2,3).
Is there any help you can give me. I don't know where the problem comes from.
Thank you very much
SepheFox
Can you post a screenshot of your flow direction? Your flow accumulation does look weird.
SamanArmal1
Yes, I think its weird either, here is a Flow-direction result:Und-1.jpg
SepheFox
Yes, something is definitely wrong with it. Do you mind posting a screenshot of the DEM?
SamanArmal1
Not at all. Here is a original DEM datasets, taken from (USGS TNM 2.0 Viewer), with Geographic Coordination of GCS_North_American_1983 and Cell size of 1-Arc second:
This is the Mosaic Dataset, as s result of the DEM tiles merging, with projection Coordination system of (WGS_1984_UTM_Zone_18N).
Thank you,
SepheFox
Hmmm, well, that looks reasonable, although it's hard to tell down in the flat areas. Something is not coming out right with that flow direction though. Maybe try running it again.
SamanArmal1
Thank you so much Mr.Fox. Don't you think the problem comes from a bay in my area of study (Chesapeake Bay watershed)? I have also a bathymetric DEM datasets of watershed. Do you have any idea if they will be helpful to rout the flow to the bay? I ran the flow_direction and Flow_Accumulation at least three times, each time at least 2.5 hours. Still not working.
SepheFox
Well, large flat expanses can do weird things, but it looks just as odd at higher elevations. Out of curiosity, when you open the raster properties of your projected DEM, what does it say for cell size?
SamanArmal1
The cell size is same as that of original DEMs: 30.92208078, 30.92208078.
