Trouble using the Fill tool in Spatial Analyst
1330
01-09-2014 07:18 AM
KellyHanne1
Hi all.  I'm having a bit of trouble filling sinks in a DEM I'm working with and would like to know if I am missing a step.  I open the Fill tool, enter the surface raster with gaps to be filled, set the location and name of the output raster and leave the z limit blank so it defaults to filling all sinks, regardless of depth.
However, my output raster has the same sinks as before.  I tried it again by setting the z limit to match the maximum elevation in the DEM, but to no avail.  Any thoughts?  It seems like this should be a fairly simple fix, but I just can't get a handle on it.  Any help would be greatly appreciated.  Thanks!
JimCousins
If you open the results tab, and view the messages from the tool, are there any errors or warnings?
Regards,
Jim
