total basin length
5233
05-14-2014 03:05 AM
AbdurrahmanGeymen
Dear Users,
I calculated the watershed in study area by ArcGIS Spatial Analyses Tools. I want to calculate the basin length that I show in the picture. How can I calculate the total basin length (the total length of the main branch) in each watershed ? Are there any tool ArcGIS 9.x or ArcGIS 10.x for this calculation? Would you please look at the attached Microsoft Word file?
http://gis.stackexchange.com/questions/71523/how-to-calculate-the-basin-length-which-point-to-which-...
Best regards.
Abdurrahman
MarkBoucher
Honored Contributor
I use Arc Hydro. It is an add on to Arc Map. The forum for Arc Hydro is at http://forums.arcgis.com/forums/88-Arc-Hydro. There you will find a sticky that gives the ftp folder where you can download it.
Also, the US Army Corps of Engineers had ESRI create HEC-GeoHMS which runs on the same tools as Arc Hydro (http://www.hec.usace.army.mil/software/hec-geohms/). If you install GeoHMS, it installs the appropriate Arc Hydro version. Either way, these have tools you can use for hydrology that are more automated than the Spatial Analyst tools, though I think at the heart they use the SA functions.
DuncanHornby
MVP Notable Contributor
Have a look at RivEX, if you convert your raster network to a vector network you can attribute your network in multiple ways, main stem being one of them. But this would be the main stem from the mouth of the network to the most upstream limit. Have a look at the online help for more information.
