Tool like Point and Line Density for Polygons?
10553
10
01-19-2016 07:51 AM
JuttaSchiller
I have to calculate a magnitude-per-unit area from polygone-features that fall within a neighborhood around each cell. Is there a tool like Point Density for polygon-features?
Thanks a lot for answering. I'm using ArcGIS 10.3.
Hallo,
ich möchte die Größe pro Flächeneinheit auf Basis von Polygon-Features, die sich innerhalb einer bestimmten Nachbarschaft um eine einzelne Zelle befinden berechnen. Gibt es ein Tool ähnlich wie Point Density auch für Polygone?
Vielen Dank für eine Antwort im Voraus.
Jutta
LukeSturtevant
I'm still rather confused as to what you are trying to accomplish here, but I'll attempt a possible solution.
Could you use
1) Create Random Points​ to generate a multipoint feature class constrained by your polygons
2) Spatial Join​  to get your population_field from your polygon
3) run Point Density​ on your population field
Or if you want to generate equally spaced points in your polygons by running
1) Polygon to Raster
2) Raster to Point
3) Spatial Join​ with your polygon and generated points to get your population_field
4) Dissolve​ your points on the population_field
5) run Point Density
