Symbolize a city as a circle and a capital as a star
1826
5
11-04-2019 09:04 PM
France
I have a state layer with cities and the usual city attributes (name, population, etc.).  The attribute table also has a "capital" attribute (Y/blank).  If the city is the capital of the state, the capital column has a 'Y', otherwise, it's blank.
I would like to display the layer with city names and:
  • If the city is not the capital, symbolize with a circle
  • If the city is also the state capital, symbolize with a star
This seems rather simple but I tried defining classes of features, using the Symbology tab creatively and checking the internet.  I can't figure this out.  I would very much welcome all suggestions.  Many thanks.
\Frances
DanPatterson_Retired
Then just make sure that you set the symbology to unique values and use the table field that differentiates state capital and non-capital
are they point symbols?
Point symbols—ArcGIS Pro | Documentation
If so, then you will have to troll the symbol sets for the appropriate one. using Unique values as the type
France
Hi, yes, this is a point file.
France
Hi, I just tried it and it worked!  Thanks a bunch!
France
Dan, thank you so much.  I can't believe it was so simple.  I was complicating it or overthinking it.  Or both.  You're the best!
