Spatial correlation between point and line geodatabases
908
03-12-2014 12:49 AM
SrikumarRoy
I am facing a problem presently in doing a spatial correlation between two sets of data. I have a geodatabase with 1000+ points and another geodatabase with around 50+ lines spatially distributed in an area. I want to find out how strongly the spatial distribution of the points are correlated with that of the lines. I  would be delighted, if you could give me a tip on this problem.
BondHarper
If you happen to have Adobe Acrobat Pro, what I do at work is export my PDF with all of my layers turned from ArcMap and then open it up in Adobe Acrobat Pro. Go to the Layers view on the left, and right click on a layer you want to be turned off by default and choose Properties. In properties you can set the Default State from "on" to "off". Then just save your document and it is ready to go. If you don't have Pro, maybe Nidhin's link will help you sort it out in ArcMap.
