Spatial Anaylist Error 010085
3377
07-07-2010 08:19 AM
EdPoole
I am having an issue with Spatial Anaylist.  The IDW feature is not working with my point shapefile and returns Error 010085 - SPOT is an invalid field.  I have checked the file, it is a high precision shapefile.  Here is the process I used so far:
  1. Created a set of graphic points based on address locations
  2. Converted the graphics into a point shapefile
  3. Tried to use spatial anaylist to make an IDW grid
  4. Error mesage
I ahve tried to convert the shapefile into a "high precision" file, but the tool claims it already is high precision...  Any thoughts, I'd like not to have to create this whole shapefile again manually...  Thanks
DanPatterson_Retired
is the field numeric?  have you tried to convert the shapefile to a grid then run the IDW?
