Spatial Analyst - Buffers?
2033
11-23-2011 10:00 AM
DanielCreech
What is the easiest way to build a buffer around a raster layer using the spatial analyst tools?...(no vector overlay or buffer tools)
Not sure which tool to use.
Needs to be a distance buffer on a polygon layer converted to raster.
Any ideas?
DanPatterson_Retired
Expand    for an outward buffer
Shrink     for an inward buffer
Information is in the help files.
DanielCreech
When expanding, I see the number of cells...
Is the zone value the distance I want to expand by?
The number of cells is the buffer size (# of cells * cell size = distance)
zone is the class/zone to expand, hence, if you want to buffer all class 1 zones, then you would use it or provide a list of values.  It is all documented in the help files, for example, for version 10 of ArcMap
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z00000036000000.htm
