spatial analysis % slope calculation with odd values
3567
04-22-2010 09:22 AM
JulieTasillo
Hi fellow GIS users:
I ran the spatial analysis slope calculation using a 2ft dem (va state plane projection in ft).  The projection of my map is in va state plane feet.  I ran the calculation for % slope with no z-factor (all units are in ft).  The resulting data has % slope values from 0-6,881.  These values seem odd to me- I would think the values should be from 0-90%? I'm wondering if others have run into this data problem and how to fix it?
Thank you,
Julie Schneider
[email protected]
ToreBorvik
did you run the slope with DEGREE or PERCENT_RISE?
EricRice
Esri Alum
Hi Julie,
Percent Slope ranges in value from 0% to infinity. AKA Undefined Slope.  Undefined slope would typically ocurr where a vertical cliff is.  Your rise is positive, but your run is 0.  So  the equation rise/run * 100 would result in undefined slope.  If your rise is 2 and your run is 1, then 2/1*100 is 200% slope. Slope is not limited to 0-90, unless you are choosing the degree slope option rather than percent.
Quite often I see percent slope values in the millions.  This ocurrs when the data has different z units than it does for x and y.  i.e. the data is in a geographic coordinate system using angular units like decimal degrees, but the z unit is meters/feet.  An example would be a rise of 1 and a run of 1 pixel (in GCS units) * 100.  1/0.00083 * 100 = ~ 120,000% slope.  You can see how not having the same units can lead to somewhat misleading slope values rather quickly.  In such cases one would project the data so the x, y, and z have the same units, or they could set an appropriate z factor in the tool.
I see two scenarios for you.  One, the data is projected in state plane with units of feet at a 2ft resolution and your pixel values (z's) are also in feet.  This is what you have stated the situation is.  You have rugged terrain, something near vertical, or at least one area that is very steep in the data resulting in percent slope as high as 6881%.  Your result is correct.  Two, you have x and y in one unit, but unknown to you the z unit is actually in different.  This situation of mixing units feet/meters is resulting in abnormally high % slope values.  Your analysis should be run again using the correct z factor depending on what unit you need to convert to.
Hope this helps you out!
