Selecting a feature within a viewshed
1292
02-28-2013 12:35 PM
JamieDavis
I have several thousand points contained in a feature class.  I have ran a viewshed analysis based on a single point.  I need to select the points that fall within the viewshed.  It seems like this should be simple: select by location, choose the target layer, pick the source layer, done.  However, raster data can't be used as a source layer.  I'm out of ideas.  Any help would be appreciated.
Jamie
MarkBoucher
Honored Contributor
Convert the viewshed raster to a polygon and select by location (do points intersect polygon).
