Region Group problems
1572
06-30-2011 05:55 AM
MichaelSutherland
I have run into a problem while trying to use the region group tool.  The output I get has this weird striping effect (see attached pdf, slide #1).  However, when I run the tool in 9.3.1 using the same data, this problem does not occur (slide #2).
Has anyone else experienced this type of problem?  If so, is there something I can do to prevent this from occurring?  Jumping between two versions really slows down my workflow and I would rather not have to do it.
Thanks in advance.
DanPatterson_Retired
this has been reported before but I don't think it has been reported, so you would be advised to do so.  see this thread
http://forums.arcgis.com/threads/17237-problem-running-region-group-tool
