raster to polygon conversion
3220
07-28-2014 10:14 AM
InceptionWoznicki
Hi Guys,
I 'm trying to automate the conversion raster to polygon and the rasters files are in "TIF" format. I have the code below. However, I 'm getting an error while executing it. Could you have some suggestion please? Thank you very much for your time and help!
Regards,
Subhasis
Code:
import arcpy, os
from arcpy import env
from arcpy.sa import *
#To overwrite output
arcpy.env.overwriteOutput = True
#Set environment settings
env.workspace = "C:/Subhasis/Test/Neshanic_Python/extract"
outws="C:/Subhasis/Test/Neshanic_Python/extract/clip/"
#checkout ArcGIS spatial analyst extension license
arcpy.CheckOutExtension("Spatial")
inraster = arcpy.ListRasters("*", "TIF")
for i in inraster:
    filename=os.path.splitext(i)[0]
    outPolygons= outws + str(filename) + '.shape'
    field = "VALUE"
    arcpy.RasterToPolygon_conversion(inraster, outPolygons, "NO_SIMPLIFY", field)
XanderBakker
Esri Esteemed Contributor
It is always a good thing to include the actual error message, since it helps us to determine the reason for which the error occurs. Another thing that would increase readability of the code, would be to use syntax highlighting. You can read more about this here:
Posting Code blocks in the new GeoNet
You do not have to import the sa module, nor is it necessary to check out a sa license. All the tools you are using are available at each license level without the need for any extension.
I notice that you define the outPolygons by using ".shape"  as extension. If you want to create a shapefile, you should specify ".shp" as extension.
Kind regards,
Xander
InceptionWoznicki
Thank you very much Xander again! Yes, I should have posted the error message and would  read about code blocks.
Regards,
Subhasis
InceptionWoznicki
The above code worked. Except I had to replace inraster by i in
"arcpy.RasterToPolygon_conversion(inraster, outPolygons, "NO_SIMPLIFY", field)"
