Raster Calculator Subtraction problems
2287
06-07-2011 05:36 AM
ErnestDunwoody
All of a sudden my Raster Calculator returns nonsense values for any expression with a subtraction in it. Just installed ArcGIS10 SP2. Related? Don't know.
I narrowed the problem down to the subtraction function. All other math functions seem okay. Math Minus tool works okay.
Anyone else with this problem? Any ideas for a solution?
Appreciate any help anyone can offer.
Edi
DanPatterson_Retired
Do you have an example?
I have come across some operands that don't work unless the operation preceding the operand (and after) is not enclosed in round brackets.  For example:
Con(("polynom2" == 5) & ("logistic" == 5), 1, 0)
ErnestDunwoody
Hello Dan,
Thank you for your reply. I worked on it some more and found the following. (Note this was not a problem in ArcGIS10 with only SP1 added.)
Using ArcGIS Modeller, when you drag the layers from the Table of Contents to the Model window and then perform a subsequent operation that includes a Minus (-) the results are that all pixels have a "0" value.
However, if you add the layers for the analysis using the Model Add "+" icon the calculation proceeds corectly. Likewise convert the model to a tool and add the layers by using the Browse button and the model runs correctly. Don't recall testing draging the layers to the tool fields.
So, I just have to remember not to drag layers to the Model window unless ESRI comes up with a fix.
Sincerely,
Edi
