Raster Calculator: no results but no error message (appears to work)
3971
10-03-2013 09:02 AM
EmilyMcKinnon
I am trying to modify a raster dataset using a formula. This worked fine at first (did 3 calculations successfully) then it stopped working. The results summary suggests that the raster was created but the raster does not appear on the map, and when I navigate to the folder where it is supposed to be saved, there is no file there.
I can't figure out what I have done wrong since the first few calculations worked fine. I did change the filenames of some of the other rasters that I created, but I don't know how this could be affecting my current calculations (which are using the original rasters that I downloaded).
I've tried different workspaces and different output locations, and trying to start again from scratch and even the 'successful' calculations that I did don't appear to work now! Any suggestions would be greatly appreciated. Thanks!
Here is what the result looks like:
[ATTACH=CONFIG]28014[/ATTACH]
MarkBoucher
Honored Contributor
My first suspicion is that the processing extent needs to be set to cover the area you are working on. Go to Geoprocessing > Environments > Processing Extent and in the pull-down menu choose a shape file or raster that covers they extent of the area you want to work on. It will place the right numbers in the "Top/Bottom/Left/Right" boxes.
