Python scripting access to SOMA and MOMA from 10.x
4725
05-17-2010 11:21 AM
curtvprice
I have an old script that uses MOMA and want to be able to run it at 10.x until I get around to doing it the new, (better) way.
I tried
import arcpy...
import arcgisscripting
gp = arcgisscripting.create()
gp.MultiOutputMapAlgebra_sa()  # error ("<s> not found")
and get an error that the tool does not exist.
The docs talk about legacy access to MOMA inside model tools, but is there a way to get to SOMA and MOMA in python?
XuguangWang
Curtis,
The following script worked for me:
gp.checkoutextension("spatial")
gp.workspace = "c:/temp/work"
in_raster1 = "C:/sapyexamples/data/inRas1"
in_raster2 = "C:/sapyexamples/data/inRas2"
express1 = "out1 = " + in_raster1 + " + " + in_raster2
gp.MultiOutputMapAlgebra_sa(express1)
A few points to consider when you run MOMA with arcgisscripting:
1. Control output workspace
2. Check out spatial analyst license
3. For MOMA expression, supply the output dataset name on the left side of '='.
Xuguang Wang
curtvprice
Thanks, it looks like I had forgotten to check out the Spatial extension on my 9.3 geoprocessor object. (I had checked it out to my arcpy object in the test script -- and forgot to do the same for my "gp" object.)
It's working fine - good to have that legacy support while we move to the brave new world of arcpy -- just in case we need it!
curtvprice
I have since discovered that this works. Just adding it here for the good of the thread
arcpy.gp.MultiOutputMapAlgebra_sa(cmd)
