Putting raster file with big extention in shapefile
828
02-06-2014 01:44 AM
AdrianeMuelbert
Hello, I have a raster file with huge extention values:
Top 2862682.68853
Left -8067545.46588
Right 17050954.5341
Bottom -2862317.31147
Spatial reference WGS_1984_Mollweide
Liniar Unit Meter 1.00000
Angular Unit Degree (0.017453292519943299)
Datum D_WGS_1984
And I want to fit it in the same projection as a shapefile
Geometry Type: Polygon
Projected Coordinate System: WGS_1984_World_Mercator
Projection: Mercator
False_Easting: 0.00000000
False_Northing: 0.00000000
Central_Meridian: 0.00000000
Standard_Parallel_1: 0.00000000
Linear Unit: Meter
Geographic Coordinate System: GCS_WGS_1984
Datum: D_WGS_1984
Prime Meridian: Greenwich
Angular Unit: Degree
I have been trying to batch in the same projection but nothing really worked. Do you know how can I do that?
Many thanks!
XanderBakker
Esri Esteemed Contributor
Hi Adriane,
That is a pretty large raster; about 63% of the earths circumference...  I'm kinda curious; what type of raster data is this, how large is it (several TBs?), and more importantly why do you want to do this?
In general it is a lot easier to project the vector data (shapefile) to the projected coordinate system van the raster. If you project a raster you will probably apply some resampling and create a second dataset (which, depending of the cell size, will probably be huge too).
Kind regards,
Xander
