Problem while trying to generate slope form DEM
1840
12-01-2018 12:51 AM
BibianRobert
Hello GeoNet Community
I have encountered a problem while trying to generate slope form DEM.1.Using the Arc hydro tool I am getting the error"Error HRESULT E_FAIL has been returned from a call to a COM component. "Kindly help.Thanks
Have also used spatial analyst tool and getting the error message" ERROR 999999: Error executing function.
Failed to create raster dataset
Failed to execute (Slope)."
DanPatterson_Retired
You will have to show the parameters that were use.  It could be a source file or destination file path issue
BibianRobert
I have changed my working folder to drive C and the spatial analyst tool is working.However, with Arc hydro the error is still the same.
