Model Builder/Python: batch raster calculation
7546
11
03-28-2016 01:38 AM
TomHawkins
I wish to carry out a raster calculation on a batch of rasters.
I want to add rasters by month, as identified by their file name.
I.e. all rasters within the month of January should add together and output a single jan.png/raster file. Then all the rasters within Feb should add together and produce a single FEB.png.
Rather than manually write a new rast calc expression for each month, I would prefer to automate it via either python or modelbuilder.
My plan outline is as follows:
Input Files. 36 Weekly raster files
01feb15-07feb15.png....
Raster operation.
(raster1+raster2+raster3+raster4)/(raster1+raster2+raster3+raster4) = month.png
output. 12 rasters for each month.
is it possible to write a python expression or create a modelbuilder which will add rasters by month using their filename?
Current Attempts
I have built a model, however this only runs on the rasters I provide it, requiring me to write a new expression each time. In other words it's the same as manually running raster calculator and writing a new expression for each month, I wish to automate this via modelbuilder.
curtvprice
Darren, the Cell Statistics tool would be a lot easier - it has an option to ignore NoData in the calculation, saving you all that work with Con!
CellStatistics(rasters, "SUM", "DATA")
TomHawkins
Adding to your notes, what I would try to achieve is this
  1. This is a list of month names.
  2. For each month name, loop through rasters.
  3. If the raster name contains the month name, add it and save it.
    • output: JAN = (janweek1, janweek2, janweek3, janweek4), FEB = (febweek1,febweek2,febweek3,febweek4)...
  4. For each month, run the set of rasters through the following expression
    • (week1+week2+week3+week4)/(week1+week2+week3+week4) = month.png
    • result: jan.png, feb.png, march.png...
