Kriging tool odd output
2466
10-13-2011 06:02 PM
by Anonymous User
Not applicable
Original User: BAK55
I am having issues when using the kriging tool multiple times on the same dataset.
I have a point feature class of soil contamination levels for 4 metals and I am trying to run the kriging tool to create 4 interpolated surfaces based on the different field values.  The problem is I do one and the results are what I expected, but I try to run the tool subsequent times using the same data and tool parameters, but am getting very strange results.  See the attached jpeg.
Thanks for the help!
http://img827.imageshack.us/img827/9485/kriging.jpg
by Anonymous User
Not applicable
Original User: stevelynch
The dataset only has 9 values which are not spatially correlated and are not normally distributed.
Which means that kriging is not the right interpolator.
A more conservative interpolator, for example, Natural Neighbor might be better.
Steve
SteveLynch
What version of ArcGIS are you using?
Are you running it via a script?
Can you send me the data and the input parameters ([email protected])
Steve
by Anonymous User
Not applicable
Steve
