Kriging - spatial analyst / geostatistical wizard
3995
03-03-2016 02:48 PM
RajPatnaik
Hi
We don't have data. To see how the results would be,  I created some random points with some values in float data type.
After which I ran geostatistical wizard. The data comply normal distribution with log transformation and also comply "stationary". I got the kriging prediction map from geostatistical wizard. The values are distributed within the range of 22.9862995 - 438.985992.
This resultant kringing prediction map when I try to export to raster, it does either (2) only exporting the covariance map from the geostatistical wizard or (2) only exponential values with no map - same way happening with the "Kriging tool" of spatial analyst.
Could anyone suggest a remedy?
Thank you
R
DanPatterson_Retired
