Kernel density units for line data
1192
10-16-2019 04:40 AM
GeorgiosKerametsidis
Is it true that when performing kernel density analysis with line data, the values on the output raster will be calculated as units of length per area units (e.g. m/m^2)?
DanPatterson_Retired
 you are using projected data I hope.
from the help
How Kernel Density works—Help | ArcGIS Desktop
Now if you want to use a multiplier, there are options
You can control the density units by manually selecting the appropriate factor. To set the density to be in meters per square meter (instead of the default of kilometers per square kilometer), set the area units to Square meters. Similarly, to have the density units of your output in miles per square mile, set the area units to Square miles.
