Joining one attribute from one shp to another
1371
6
05-22-2013 08:12 AM
mileslayne
I have two separate files, one is Manholes, and the other is Sewer Lines. I have a Field in the Manholes attribute table that i created called Seg_ID. Now All of my points (manholes) are snapped onto the sewer lines. Each sewer line is label SL_1, SL_2, SL_3 etc etc... How can i get the field in the manholes file to automatically say which sewer line each point is on in the Seg_ID field?
JeffreySwain
Have you tried a spatial join?
mileslayne
I have tried a spatial join, i thought it worked, but what happens is that since my manholes are snapped to the sewer lines it messes things up. I found that if my manholes is snapped at an "T" intersection it makes three copies of the manhole, It says manhole 3 is on SL_54, SL_57,and SL_63 those are just examples. So it takes my 1375 manholes and Turns them into 1800+ manholes.
NobbirAhmed
Esri Alum
Could you please let us know what parameter values you are using? Especially, these ones:
Join Operation
Keep All Target Features (checked? unchecked?)
Match Option
When a manhole is snapped to a T-section then the manhole actually belongs to all of the three, no? In that case, how do you want to determine the sewer line it should belong to?
mileslayne
Target features are manholes, join features are sewer line.
1 to many join operation. Check keep all target features. I don't care what line the manhole is on, the software can choose any one
it wants for all i care. I just don't need it to make triples every time a manhole is at an intersection
NobbirAhmed
Esri Alum
Most probably you are using INTERSECT option. Use CLOSEST match option instead - only 1 will be chosen as join feature.
mileslayne
I am fairly sure that worked, thanks alot for the help!
Miles,
