Issues with clipping
3607
04-01-2011 01:01 PM
JamesDiPaolo
I am trying to clip one layer with another. I keep getting "WARNING 000632: Datum conflict between map and output." An output is produced but the attribute table is empty. Any ideas?
TimothyHales
Esri Notable Contributor
This error usually related to having the data frame coordinate system different from the layer coordinate system.  Try opening a new blank map document, add the layers, and then perform the clip.  You might also check to see if the coordinate systems are different between the layers.
