Interpolation issue
2592
02-13-2014 06:01 AM
by Anonymous User
Not applicable
Original User: elinmaria
Hi!
I have encountered the following issue:
I have xyz data (.txt) that I want to create rasters from. So, I made them into shapefiles and used spatial analyst-natural neighbor. Everything worked, got my rasters.
BUT when I noticed that one of the txt files needed editing, I edited it in Excel (reduced the elevation, z, value for all cells). Redid the process with importing it to Arcmap (10.1). But the interpolation won´t work anymore. I get the following error: Error 99999. Error executing function. Tin is not in edit mode.
I tried several times, but no success. Hope someone can help!
Cheers!
by Anonymous User
Not applicable
Any suggestions very welcome..
JimCousins
The reference to a TIN does not make sense, as the output is a raster dataset. Perhaps it is simply an overwrite issue? Are you creating a new raster with the revised data?
Regards,
Jim
