internal grids rowmap/colmap/xmap/ymap
8807
6
12-03-2010 03:24 AM
HugoAhlenius
What is the latest on internal $$RowMap etc grids in ArcGIS 10? One has to go the numpy route?
MannyGimond
Unfortunately, that seems to be the only solution for now. You might want to add your voice to the ArcGIS "wish list" at ideas.arcgis.com. An arc grid request has already been created. Click here for a direct link.
HugoAhlenius
Thanks for the link - I have voted it up!
DanPatterson_Retired
From this thread, in version 10
http://forums.arcgis.com/threads/865-quot-built-in-quot-rasters-in-python-map-algebra
try the example
import numpy as np
import arcpy
#source http://forums.arcgis.com/threads/865-quot-built-in-quot-rasters-in-python-map-algebra
#with some fiddling
# Setup some rasters of rows and columns
# (like old $$ROWMAP and $$COLMAP)
arcpy.env.workspace = "c:/temp"
arcpy.env.overwriteOutput = 1
nprows = np.indices((10,10))[0]
npcols = np.indices((10,10))[1]
# Convert the numpy arrays to ESRI rasters (ie Raster objects)
# called 'rows' and 'cols'
row_ras = arcpy.NumPyArrayToRaster(nprows)
row_ras.save("rowraster")
col_ras = arcpy.NumPyArrayToRaster(npcols)
col_ras.save("colraster")
print row_ras
print col_ras
Luke_Pinner
MVP Regular Contributor
I found I can use the built in GRID variables or scalars in ArcGIS 10 with a bit of a hack.  It appears that the python arcgisscripting module is still included in Desktop ArcGIS 10, perhaps for backwards compatibility (or perhaps I didn't uninstall 9.3 properly...), so I wrote a little script that uses the SingleOutputMapAlgebra tool, created a script tool and added that to a custom toolbox and then just use that as required.
import arcgisscripting
gp = arcgisscripting.create(9.3) #This works in ArcGIS 10!!!
expr=gp.getparameterastext(0)
output=gp.getparameterastext(1)
result=gp.SingleOutputMapAlgebra(expr,output)
I've attached a screenshot.
curtvprice
Luke --  arcgisscripting is still there under arcpy. (You probably know this by know as this post was 2011!)
So this works (for now anyway).
import arcpy
arcpy.env.scratchWorkspace = r"D:\Users\cprice\work"
arcpy.CheckOutExtension("spatial")
arcpy.env.extent = arcpy.Extent(0, 0, 10, 10)
arcpy.env.cellSize = 1
arcpy.gp.SingleOutputMapAlgebra_sa("$$ROWMAP"), "rowmap")
curtvprice
   The best workaround I found in that environment was to compute flow accumulations for constant direction grids (and unit weights): $$ColMap is the flow accumulation of a grid filled with 1's and $$RowMap is the flow accumulation of a grid filled with 4's.
I did an implementation of this idea in arcpy map algebra here:
arcpy map algebra $$ROWMAP, $$COLMAP
