Installed Extensions Not Authorized
8116
11
01-26-2012 08:01 PM
AlgerBeal
According to ArcGIS Administrator, my 365 day educational trial version of ArcMap 10 has Spatial Analyst installed, yet it says the license is not currently enabled or available.  Does anyone know if I am able to acquire Spatial Analyst with an educational trial version?
V_StuartFoote
Renny,
You should not have to enable the Data Interoperability extension to be able to apply its SP2 to it.  Do you have FME, or anything else other than the ArcGIS Data Interoperability Extension using SAFE components. You look to have Autodesk products installed--they make use of SAFE Software modules, could be conflicts there.  It is possible, you may need to uninstall one or the other sets. But if you are going to keep the Data Interoperability extension you do need to install SP2. Not stricly necessary, but I install its SP2 before installing Desktop SP3.
Also, ESRI service packs are cumulative. So after your base install--you only need SP3, and any additional patches after it.  The 3rd party extensions get their patching from their vendors and are handled in parallel to Desktop--ESRI bundles Data Interoperability with Desktop but it is maintained by SAFE Software.
for Alex--No, Data Interoperability is not installed by default with the base ArcGIS Desktop 10.0 install done for Education users. In fact the same DVD media image is used for ALL Desktop 10.0 installation (download or DVD) and installation is done from the ESRI.exe installer panel as for the rest of us. Just the activation steps differ for the Education, ESRI Press and 60-day trial authorization numbers--the extensions are activated as a bundle.  I knew Renny had installed it looking at the ArcGIS Administrator screen.
Stuart
AlgerBeal
Thanks Stuart.  I will look into that and try to resolve the possible conflict.  I may pester you again if I don't have luck with my attempts.  Thanks again for your time and knowledge.
Renny
