IDW doesn't work on my arcgis demo 10 (merged threads)
2775
12
04-05-2012 10:05 AM
GiacomoRossi
Hello, I've installed on my notebook the ArcGis 10 demo version, and I need the IDW tool to make an interpolation analysis for my G.I.S. master thesis that I've to finish as soon as possible. Unfortunately, the IDW doesn't work for any of point data I have. Only the first I manage to create. It is not specified also which kind of error it is done:
Can you help me, please?
curtvprice
I sent to the geoprocessing team my problem
Note, you will most likely not hear back, this is an automated dialog that collects information using a web robot. If you want assistance from Esri Support, you need to contact them at support.esri.com and open an incident.
Arc 10 Help: Frequently asked questions about error reporting
ArcGIS Blog: ArcMap Crashed? Send us your report!
JoshThompson1
It looks like these are points which are located in some sort of ditch (?).  If so, and wish to use the outlined area as a constarint, you might try using the barrier option for the IDW tool.  This may at least get it to run successfully.
Josh
SteveLynch
