How to select the maximum value in a row
1830
06-02-2019 11:48 PM
KK2
I would like to know if there is a way to find a maximum value in an attribute table in a row.
I have few columns representing different valuables of an object and I would like to know which variable has the highest value across all of them? Is there a ready to use function to do this? Thanks in advance for your answers.
NeilAyres
I don't know of an existing tool to do this.
You may want to try a little python, like this (btw completely untested)
import arcpy
pathtodata = r"c:/some/path/to/data/db.fgb/mydata"
flds = ["field1", "field2", "field3"]
with arcpy.da.SearchCursor(pathtodata, flds) as Cur:
    for row in Cur:
        minval = -9999999
        minfld = None
        for v in range(len(flds)):
            if row[v] > minval:
                minval = row[v]
                minfld = flds[v]
        print "Fld {} min {}".format(minfld, minval)
NeilAyres
Those variables
minval, minfld
should of course be named
maxval, maxfld
for clarity.
KK2
Thank you for your answer, but If I understand you correctly this script will find the minimum values only (at least such results I achieved by running this script). I do not have the minimum values and I am asking whether it is possible to calculate the values of each angle of a polygon in Arc Map, and then to find those that have very small values.
