How to reclassify portion of a raster
2207
06-29-2016 10:22 AM
RamB
I want to reclassify on a certain range of values in a raster. For values not belonging to this range, they should remain the same as the original raster. I need to do this for nearly hundred rasters and will be doing this again and again every few months. So, Any hints would be of great help.
thanks
Srirama
DarrenWiens2
You can write a Map Algebra Con statement (e.g. "if this, then that, else (if this, then that, else (if this, then that, else leave alone)))").
DarrenWiens2
