how to extract perimeter cells from raster
2042
02-28-2012 08:28 PM
CathyReidy_Liermann
Hi all,
I've got a raster dataset from which I need to extract all the cells representing the perimeter (the raster is of runoff, and I need all coastal runoff).  I was thinking that I could query cells that neighbor a null value (non-land is null value), but I don't know how to craft such a query, or if there's a tool already in place to do this.  Any other ideas of how to select perimeter cells?
Thanks!
Cathy
PrasantaBhattarai
Hi Cathy,
If you have Spatial Analyst extension, here's what you can try:
1. Create a polyline for the boundary of your raster
- Reclassify your raster to 1 value.
- Convert Raster to Polygon > Buffer it inside with 1/2 the cell size and convert it to Line
2. Run Extract by mask tool and use the polyline feature as mask.
3. Convert your output (mask) raster into points.
(grid_code is the pixel values from your runoff raster for each cells)
If you have 3D Analyst extensions, here's what you can use:
1. Use the Raster Domain tool to create a 3D polyline
2. Convert each vertices of the polyline into points using Feature Vertices to Point (requires ArcInfo)
3. Run Add Z information tool to get Z values into the attribute table for the points.
(Z values are the pixel values from your runoff raster for each cells).
Hope this helps!!!
CathyReidy_Liermann
Thank you so much!  I did the first option in SA and it worked great.
Cheers!
Cathy
