How to determine structure elevation from contour interpolation
3210
07-23-2012 09:56 AM
JustinWaples
Is there any way I can use elevation contour lines to interpolate the approximate elevation of structures that are at ground elevation, e.g. manhole rims?
If yes, is there a way to do the analysis for all my structures at once?
Justin
MarkBoucher
Honored Contributor
You can convert the contours to a DEM (raster) using Spatial Analyst Tools>Interpolation>Topo to Raster. Then extract the elevation of the DEM to the points that represent the structures using Spatial Analyst Tools>Extraction>Extract Values to Points. The finer the DEM (the smaller the grid size), the more accurate your structure elevation will be.
