How to combine these three rasters according to this logic?
2474
05-25-2011 12:25 AM
by Anonymous User
Not applicable
Original User: [email protected]
please, see the attached images that show my question
explanation:
I've three rasters: slope, landuse and hydraulic conductivity. i need to combine them according the relation shown in the table (second attachment)
i convert the table shown in the second attachment to the following code:
if [Type] = "FieldCrop-Shrub" then
          if [FlowType] = "TYPE D" then
             Select Case [Slope]
    Case 1
       oo = .6
    Case 2
         oo =.4
    Case 3
        oo =.2
    Case Else
       oo =0
End Select
           else
          if [FlowType] = "TYPE E" then
             Select Case [Slope]
    Case 1
       oo = .8
    Case 2
         oo =.6
    Case 3
        oo =.4
    Case Else
       oo =0
End Select
          end if
end if
else
if  [Type]  = "Forest" then
             Select Case [Slope]
    Case 1
       oo = .8
    Case 2
         oo =.6
    Case 3
        oo =.4
    Case Else
       oo =0
End Select
           else
             Select Case [Slope]
    Case 1
       oo = 1
    Case 2
         oo =.6
    Case 3
        oo =.4
    Case Else
       oo =0
End Select
end if
end if
end if
end if
Now, how can i include this code to combine these three rasters?
thank you
regards
Jamal
DarrenWiens2
MVP Alum
I know this is an old thread, but it popped up to the top, so here's a quick answer. The equivalent of if/then/else logic for rasters is the Con tool/statement.
Con(condition,do this if true, do this if false)
Abdul_HameedKhorami1
XanderBakker
Esri Esteemed Contributor
As an alternative one could use the Combine—Help | ArcGIS for Desktop  tool to combine the rasters (have to be integer) and perform the analysis in the attribute table (create a new field with the result) and use the Lookup—Help | ArcGIS for Desktop tool to create the output raster based on the generated field.
