Help with RASTER Calculator!
824
11-21-2011 07:58 AM
AlexandraHestilow
I am taking a class and they are asking me to create a binary raster from a distance surface that I just created suck that pixels within 2-4 miles distance to the existing police stations and storefronts will be coded 1 and zero otherwise. I need to also convert the units from mile to meter in the raster calculator.
I am not the best at raster calculator so can anyone help me on how to write this out?
Alex
DanPatterson_Retired
Homework requires you show what you have tried so far.  Also, specify the version of ArcMap.
AlexandraHestilow
I just don't know how to write out the code properly. I had to do this previously and it worked but now I have to convert miles to meters also and I have no idea how to write the code out.
Earlier I had to: create a binary raster from a crime density surface such that the pixels with a crime density higher than 15 will be coded 1 and zero other wise:
CON(densityraster > 15, 1, 0)
I am just lost on how to write the new one including telling it to convert miles to meters
AlexandraHestilow
I am working with 9.3.1 right now
