HELP: Least Cost Path Analysis
2785
04-23-2019 03:24 PM
EmilyShepherd
I am trying to do a least cost path analysis connecting two villages on an island. I am following an e-learning tutorial called "Distance Analysis Using ArcGIS Pro".
I created a slope raster from a DEM and I created a vegetation raster from a feature class as well. I reclassified them so they have values ranging from 1-11 (with 11 being the most costly). I keep trying to use the "cost distance" tool, so I can then use the "cost path" tool, but I keep getting an error that says "Something unexpected caused the tool to fail". I have tried clipping the rasters so they are zoomed in on the two points to help cut down on data and making sure they are in the same coordinate system. Nothing is working.
Can anybody help me figure out what the problem is?
If not, is there a way to create a least cost path using only slope?
Thanks!
DanPatterson_Retired
file paths and names... spaces? punctuation? raster type  and destination? (ie *.tif to a folder, esri grid etc)
That cryptic message has more to do with things unrelated to the actual tool, but the environments that you are using.
EmilyShepherd
Are you suggesting I try a shorter file path or changing it to a .tif?
The file names shouldn't be a problem.
EmilyShepherd
It worked!! I made the file pathway shorter and the cost distance tool worked.
Thank you for the help!
Glad it worked out... paths and filenames give rise to many seemingly unrelated problems
