Graphing records in attribute tables
2748
01-28-2011 11:33 AM
LouisWasson
Hi
Is there a way to graph a record and its associated fields in an attribute table?  I have 11 records that represent 11 watersheds.  Each watershed (record) has 15 decriptive fields decribing the watershed such as forest, urban, open water, etc.
The graph tools only allow you to graph one field for all records. For example, if I graph the counts for forest it will display the forest counts for each record.  I want to isolate each watershed (record) not the fields.  Make sense?  I can do this in Excel as a series but I would like to do it as a tool in Model Builder.
Thank you,
Louis
LouisWasson
I figured it out.  Using the Spatial Analyst Zonal Histogram Tool a table is created where the watersheds are fields and associated watershed information are records.  Now I can use the graph tool display landuse/landcover information by watershed.
Louis
